Is there a way Rachio can control the flow of water into a fountain? Is there a sensor that would tell Rachio to fill and tell Rachio it’s full and to stop filling?
You could set a schedule that runs the zone for longer than required to fill the fountain, then use a float switch or other sensor that opens the line to the solenoid when the fountain reaches the desired level.
