Confusing Home Screen
This made me so frustrated, I fixed it with a tampermonkey script…
It would likely have been easier, if your code is open sourced.
This is not the best code, but works.
In case you are interested.
// ==UserScript==
// @name         Rachio Reorder Calendar
// @namespace    http://tampermonkey.net/
// @version      0.1
// @description  Rachio Reorder Calendar
// @author       Duane May
// @match        https://app.rach.io/locations/*/devices/*
// @match        https://app.rach.io/devices/*
// @icon         https://www.google.com/s2/favicons?sz=64&domain=rach.io
// @grant        none
// @run-at       document-idle
// ==/UserScript==
function getDaysArray() {
    let daysOfWeek = ['Sun', 'Mon', 'Tue', 'Wed', 'Thu', 'Fri', 'Sat'];
    var dates = new Array();
    dates.push("Today");
    var date = new Date();
    for (var i = 1; i < 7; i++) {
        date.setDate(date.getDate() + 1);
        let dayOfWeek = date.getDay();
        dates.push(daysOfWeek[dayOfWeek]);
    for (i = 1; i < 9; i++) {
        let formattedDate = (date.getMonth() + 1).toString().padStart(2, '0') + '/' +
            date.getDate().toString().padStart(2, '0');
        dates.push(formattedDate);
    return dates;
function main() {
    console.log("Reordering dates");
    var sections = document.getElementsByClassName("test-location-schedule-container")
    if (sections.length == 0) {
        return;
    var childrenOfSection = sections[0].childNodes;
    if (childrenOfSection.length == 0) {
        return;
    var div = childrenOfSection[1].childNodes;
    if (div.length == 0) {
        return;
    var container = div[0];
    var dates = getDaysArray();
    var newOrder = new Array(dates.length);
    var childDivs = container.childNodes;
    for (var i = 0; i < childDivs.length; i++) {
        var childDiv = childDivs[i];
        var divs = childDiv.getElementsByTagName('div');
        if (divs.length == 0) {
            continue;
        sections = divs[0].getElementsByTagName('section');
            continue;
        divs = sections[0].getElementsByTagName('div');
            continue;
        var dateDiv = divs[0];
        var matchValue = dateDiv.innerHTML
        var index = dates.indexOf(matchValue);
        newOrder[index] = childDiv;
    for (i = newOrder.length; i >= 0; i--) {
        if (newOrder[i] == null) {
            continue;
        console.log(dates[i]);
        container.insertBefore(newOrder[i], container.firstChild);
(function() {
    'use strict';
    window.addEventListener('load', (event) => {
        console.log('The page has fully loaded');
        setTimeout(function() {
            main();
        }, 3000);
