Can't Connect to Wifi
I have had the Rachio 3 for over a year with no issues. We had a power outage and now it won’t connect to wifi. I have tried all the tips/tricks offered on the website. The Rachio is flashing white with red. in the 1st quadrant. I have rebooted my router, unplugged the power/pressed white button. I have tried resetting my wifi and that didn’t work either. I received the email that states the Iphone-IOS update of 13.4 or higher is not compatible. What good is having the app on your phone, if you can’t use it on your phone?! I also tried using my older Ipad Mini 2. It still doesn’t work. I have run the scan on RouteThis Helps, and am waiting to hear back. I don’t know what else to try. Why was this working on my Iphone prior to the power outage and now it won’t?
@1RedChic - That light pattern appears to be the Boot Error 1 status from:
I don’t think this has anything to do with the WiFi environment.
The iOS warning if for first time setup. Your Rachio should have received a firmware update that would work around that.
I’m not sure that a Factory Reset would help. I’d call or email Rachio support for this issue.
