I’m new to Rachio (installed during winter and didn’t even get to test if I did it right until a couple of weeks ago). I’ve been playing with the app and can’t seem to get the calendar to refresh when I change/delete/add a schedule. I’ve tried killing the app and restarting, but no luck so far.
Any thoughts? Thanks!
P.S. The new firmware seems to have solved my mesh-HomeKit problem! Thanks for that!
Franz is right that it’s usually pretty instantaneous. In case you ever see issues with updates again, you can force a re-registering of update events by signing out and signing back in (this happens periodically over time too). If everything is working well now though, you won’t need to do that. Hope that helps!
