Another Arizona Set-up help thread!
Not nearly enough! I think it would run about once a week. It was fine when I first got it set up and the weather was cooler. Once it got hot, it wasn’t even close to enough. Changing soil type, and fixing a bad calculation on the 2gph emitters (pulled from the boards here) bumped it way up and trees are set to run on the 10th, shrubs on the 15th.
