Android App - Smart Hose Timer schedule Color setting not working
I’ve got two valves in my Smart Hose Timer and I’m trying to set individual colors to each valve (option in the application).
Reproduction efforts:
  1. Click the smart hose timer, I have two setup - one for Trees and one for Beds.
  2. Click Schedules at the bottom.
  3. Click on a scheduled time’s three dots options.
  4. Click Edit Schedule.
  5. Edit the color and a popup of available colors shows up.
  6. Try selecting a color and click SAVE. At this point, the Color pop-up window comes up again and allows you to select a new color, not saving the previous choice. You have to click CANCEL instead and the color does NOT save.
This is the software bug I’ve run into. I don’t think this is a problem with the hardware itself as it works great.
I’ve given this info to support, but wanted to check to see if anybody else has this problem.
Can this be fixed in a future Android app update?
Thanks for reporting this issue with clear steps to reproduce. We have a fix for this issue and we will get this added in the next release.
Thanks again,
Steve
