using the manual controller is really jumper, very hard to get it to a certain time, didn’t used to be like this.
i picked one zone, set it to run for 8 minutes, then picked a 2nd zone and set it to run for 7, it only ran one of them but reported the total run time for both.
I don’t think any code has actually changed in the remote recently so I’m wondering what has happened.
If you set a time of 60m and hit the reset icon do you see the knob control animate back to zero smoothly or does it jump there too?
I’d say it a little differently… setting the manual dial was always smooth for me, but I usually end up adding or dropping a minute when I take my finger off the screen. So I have to try and dial it back in and remove my finger more slowly/carefully. I can live with it but it does happen to me almost every time.
@franz I’m having an issue using the Android app, on my Nexus 6p and Samsung S4 for viewing Moisture Levels… When I first click Moisture Level only the title appears at the top while displaying a blank white screen. If I use the back button and then click Moisture Level again (sometimes takes 2-3 times) then it will display the graph. Blank Screen
I can confirm this on my Nexus 6p. Didn’t report it because it doesn’t happen every time I open the moisture graph, but it does happen quite frequently.
Thanks everyone, we will sort out. Native charts are way easier in Android (but take much more time to build), this is using a Web view. It renders the same graph used as the Web app.
