When I set up a schedule, I am not able to see the time allocated to the soak. The only way to know is for the schedule to activate. I would be great to be able to override the base time. For example, select a box to override that then unprotects the calculated base time, allowing adjustment. At a later date, by unchecking the override box, the system goes back to the calculated base time.
Access to Base Watering Time with Override Function
chris
#2
@PocketLab,
The zone durations are in each individual watering time. If you tap on ZONES & DURATIONS in a watering time, you’ll see a list of zones with their runtimes for the schedule. Upon initial Watering Time creation, we set those durations based on the season and your zone attributes. However, you can adjust those if you like. Our system will then make seasonal adjustments on what you have changed.
