Have a new gen2 system using 4 zones. Is there anyway to change the run order of those zones without having to change the specific valve wires. Ie. I now want zone 4 to run 1st and zone 1 to run 3rd.
Would love this option as well!!!
If you are using iOS or Android you can press and hold your finger on the zone in the edit screen for the watering schedule and you will be able to re-order the zones.
Does this help?
Here are some screenshots.
Yes. Just tried ok iOS and it works perfectly. Thank you so much.
