Zone duration question
I am new to Rachio but not to irrigation systems. I also realize that 2.0 will probably change everything shortly. I have all the automation turned on.
I went to set watering times and Rachio automatically determined the duration and the number of times per week (every 3 days) which seems like a default frequency. When I set the frequency to every 7 days, the duration doesn’t change. Do I have to then set the duration manually to accommodate the reduced frequency? So for instance if Rachio set the duration for 10 minutes every 3 days, when I switch it to every 7 days should I manually adjust the duration to 24 minutes to compensate?
@nillooo13 Yes, the software does not currently modify duration if the frequency is changed.
Thanks and let us know if you have any other questions.
Yes, it will :wink:
Keep an eye out of v2.0 updates. Here’s the latest in case you missed it today: 2.0 Preview - Flexible Schedules
