Hello, folks!
I was going over the hardware I received and noticed a sticker inside the outdoor enclosure indicating that I must remove the Rachio 3’s faceplate when installing the unit into the outdoor enclosure. I thought it might be because of a clearance issue, but I placed the Rachio unit, with its faceplate attached, into the outdoor enclosure and the enclosure’s door closed fine. In other words, there doesn’t seem to be a clearance issue, as originally suspected. Is there another reason why the faceplate must be removed?
Please let me know.
Thank you for your time!
