rioncm
July 15, 2019, 4:44pm
I’m receiving an error when I try to setup a webhook for one of my devices.
{"code":"203","error":"Error creating webhookwebhooks required"}
here is the API call I am making via PAW rest client.
POST /1/public/notification/webhook HTTP/1.1
Authorization: Bearer my-bearer-code-000-00000000000
Content-Type: application/json; charset=utf-8
Host: api.rach.io
Connection: close
User-Agent: Paw/3.1.8 (Macintosh; OS X/10.14.5) GCDHTTPRequest
Content-Length: 181
“device”:{“id”:“my-rach-io-device-000000000000”},
“externalId”:“vnWestTest”,
“url”:“http://mqtt.myurl.com/rachio/vnwest ”,
“eventTypes”:
{“id”:“1”},
{“id”:“2”},
{“id”:“4”}
Any insights in to what I am doing wrong?
R
franz
July 16, 2019, 4:12am
2
Those types are not valid.
This will give you the valid types.
5
DEVICE_STATUS
6
RAIN_DELAY
7
WEATHER_INTELLIGENCE
8
WATER_BUDGET
9
SCHEDULE_STATUS
10
ZONE_STATUS
11
RAIN_SENSOR_DETECTION
12
ZONE_DELTA
14
DELTA
@franz is this the correct object I need to send to the api to create a new webhook? The eventTypes listed on the example in the documentation’s curl example seem to require an array of objects with id and value (e.g [{“id”: “1”}]
Create the webhook
webhook_data = {
“device”: {
“id”: device_id
“externalId”: “any_string_you_want”,
“url”: webhook_url,
“eventTypes”: [
{“name”:“ZONE_STATUS”,“type”:“WEBHOOK”}
franz
June 9, 2023, 2:50pm
4
Can you PM me the curl command you are using?
