I have installed 9 systems for clients. When setting the weather station, the map shows the house location of the first Rachio I installed in Echo Park. How do I customize the physical address of each house so it populates the closest weather stations, not the closest to my 1st Rachio location?
This is tricky unless you are at the physical location of the house with the smart phone to update the device location.
This article explains how to update device location automatically.
If you are not at the physical location you can use the Webapp (https://app.rach.io ) and manually enter the latitude/longitude of the controller if you know it. This is adjusted through Device Settings.
Hope this helps.
