Weather Adjust
I am replacing a Pro-C controller that had a rain sensor with the Rachio. We have fixed watering days in the area so I am limited to what options I can use.
The pro-c monitored the average temperature of a block of days and would adjust the system watering time up or down if needed. This was done as a percentage and if the weather was warmer than normal it would water 110 Percent, if we had an unusal cool week the adjustment was down to 80 percent. I was also able to adjust the percentage if I felt it was too dry, the system would slowly over a week adjust back. This was a simple adjustment I could make at the controller to change all the cycle times if needed.
This was a nice option as I find myself adjusting the cycle times often. It was an unusual few weeks of dry hot weather and I didn’t keep up with it, the lawn is suffering.
Otherwise I am very pleased with the system.
Ron
I installed a local weather station, as I am in a shadow of a 14’k mountain, and local reports don’t mean I got what they say I got, even within a couple miles. I have been very happy with it. It might be an option.
I know in the rachio3, they say don’t use a local weather station, but I had to, it might be something worth locking for a more local station if you live in a micro-climate like I do.
I also have found that taking the time to adjust the advance parameters to meet my conventional watering , to a minimum, has been working well.
