Since we have the ability to see in real time in the powermeter graph when we turn devices on and off. Why not give users the ability to “tag” a waveform? And Sense in the back end can use that tag to improve the device matching DL/ML models. It will have a 90% success rate. It already tells you the “delta” in wattage - if there is a way to tag that delta… we’d be set!!
