Under “Watering Time”, what happens if I answer yes to “Is this a watering restriction?”
George
George
@p3pilot As the months change we will adjust the watering times for the device if you have Water Budgeting turned on for the given schedule. We will be building in functionality that will eventually shift days around. When a watering time is set as a water restriction, we would assume that we shouldn’t move days around for that schedule.
