Hi,
My water usage graph is blank:
Anyone know how to fix it (it just watered today)? I bought/installed the Rachio last November and only recall one month where the graph appeared to be working.
Hi,
Thanks for reporting this, will have our web developer @Dan check on this and get back to you.
I do see data on Android, so it seems like a web only issue.
Thanks again and have a great day.
I see this as well.
I find if I click minutes then gallons it renders properly… usually.
Just started about 2 weeks back.
OSX Safari. Latest “standard” (non-beta) version.
Playing with it a bit, I think it is a problem based on screen/window size perhaps?
Smaller windows aren’t rendering properly.
I am using Chrome - version 49.0.2623.75.
I also use an extension called uBlock Orgin. I turned it off and the graph appeared to work. As soon as I turn it back on it stops working. Is there a ip address that I should be whitelisting in uBlock Orgin so it doesn’t block the graph?
Ok, so whitelisting api.keen.io didn’t work, but whitelisting app.rach.io did.
Thanks for your help!
