Just got the Rachio system, but I have the following questions with suggestion:
Water Control:
- Notice there is Water usage report in the dashboard where it report how many gallons has been used . May I ask how the system calculate it? As different water pressure , nozzle type could have different result.
- Is it possible to customize it for reset it?
Suggestion:
- During the Drought period, it is very important for the user to monitor the water usage. Although the system does provide the water usage, however if the data is not accurate it is not quite useful.
- The water usage section would turn to be very useful if:
a) allow the customer to reset the water usage which match the water billing cycle. (for mine is every 2 months )
b) I Allow the customer to enter the water usage of each zone , and the overall water-usage is base on the customer data.
For example:
- I did check the actual water usage of each zone by checking the water meter:
zone 1: 10 min of water use 0.20 cubic feet
zone 2: 10 min of water use 0.30 cubic feet
Therefore, the “water usage” section could truly represent the actual usage.
c) Allow the customer to define the CCF usage limited:- It is important for the customer to define the water usage per period (months or every 2 months) during the drought period. The customer may consider the water usage in priority vs grass healthy.
- Therefore if the customer allow to enter the CCF for watering it would be useful.
- Per b) since the system could report the water usage accurately, if the user define the CCF limit, the system could
i) prompt the user if the CCF for watering is X% to limit set
II) prompt the user base on the water schedule, it will XX% below/above the CCF limit
iii) prompt the user if the user want to change the water usage
-or-
The system could minor adjust the water schedule’s min by % to fit the CCF limit
I wish Rachio could consider the above suggestions.
Thanks
Samuel
