I probably overstated the issue in my initial post.
I’m generally not creating a lot of schedules. I was creating several new schedules recently, however, and that’s when I noticed how tedious this becomes. First, in response to this: Rotor Head Precip Rate. Then, in response to debugging this: Sun/shade not affecting run time. So, I probably created 6-8 schedules in a span of an hour or so…
This just seemed like such an arbitrary setting to fix as default for every new WT, since folks are dealing with water restrictions that are going to constrain every WT they create in the future. And in my case, once I have forgot to change this 3-day setting (user-error) and it resulted in watering on a non-watering day.
But to be clear, this is a “nice to have” feature request, and if it can’t feasibly be changed that is perfectly OK. Thanks for the follow-up.
Chris
