It appears to me that flex daily irrigation times are basically set by the zone configuration, and the irrigation schedule is then automatically adjusted by skipping or advancing days… Is this correct? Or does flex daily actually adjust irrigation times also?
Thanx
Correct. Irrigation times are fixed since we water fully to fill your zone ‘bucket’. Once filled we track soil moisture daily and don’t water until the zone is depleted. I call flex daily schedules the anti-schedule since they don’t have a set schedule.
You can look at each zones soil moisture graph to see forecasted two weeks of simulated watering. Hope this helps.
Thank you Franz, .
