We purchased a home that had the Rachio up and running. Transferred everything over to us and now I even have the pictures on each zone from the previous owner and all previous settings but nothing turns on. Need some help
@cvalle - welcome to the community! Is there a separate manual cut-off valve that has turned the water off to the entire sprinkler system?
Is there a master valve in the system?
Is there a rain sensor that is wired into the common wire?
Does water come out of the zone when the manual bleed screw is turned on a zone (if there is a master valve, it will have to be opened too)?
Do you have access to an volt/ohm meter to check resistivity down a zone wire and voltage out of the Rachio?
Which generation of Rachio do you have? Gen 1 is square, Gen 2 has the status light in the formation of the Rachio logo and Gen 3 has a light bar across the front as the status lights.
Ok so it was a simple fix… the previous owners has shut off the system at the main valve before they left. Smh lol thanks for the reply!
