Temperature Based Cycles
I’d like to see the ability to add a cool down cycle if the temperature reaches a certain threshold. For example, in the summer I’d like to set a short 1-2 minute cool down cycle for the grass and plants that get full sun. Rachio would look at local temperature data and if it reaches above {90 degrees}, then the cool down cycle will run, if it doesn’t then the cycle will be skipped. Also, I’d like to see Rachio support a conserve cycle if the temperature falls below a certain threshold in the winter time. This would be in addition to the Flex Schedule, which I don’t feel addresses summertime temperatures.
Yea I like the idea of syringing the turf but the chance for burn and wet wilt goes up a lot
I feel pretty confident that flex handles thes temp extremes, have you seen it fall down
