I just got a Gen2 8 zone controller. Hooked it up in minutes and had it up and running. Today was my first day scheduled to water. Set it for 8am. I was too excited to see it work, so i went to edit schedules and selected “Run Schedule” everything worked like a charm. Went to work, got the notification that it finished and then immediately got a notification that it is starting to water again. Is this a glitch or is it because I didn’t let the system run on the timer and it was just waiting for it to be done to go again? Thanks!!
@livewyr25 If you manually run a scheduled schedule it will not preclude that same schedule from running again at its predetermined time
so even though it is an hour later, it will still try to run the 8am time?? Thanks for the reply
Yes, running a scheduled schedule manually (at any time) will not affect when that schedule will run at its predetermined time.
