I put a deep well pump in a well on my property.
The Rachio 3 pump contact correctly powers the relay that runs the pump. BUT my well runs empty after 15min of watering. Unfortunately I haven’t found a setting that allows the pump to stop after 15 min of watering and let the well fill itself with water for 30min before running again for the next 15min max.
I’d love to have this feature in order to take full advantage of the automatic watering feature.
I already have the delay between zones set up, but on automatic the water often runs much longer than the desired time and the empty well swimmer switch cuts the power to the pump while rachio still believes it is still watering.
Please add the required features to the pump connector settings.
