in 1.x it was recommended to set a separate “watering time” for each zone so the seasonal adjustments could be made to each individual zone… is this still recommended?
The reason I ask… is I have 9 zones… when I have each on a separate watering time, it waits to complete each zone before moving to the next. Add in the 30 min soak time on a few zones and it can take 3-4 hours to get through watering my lawn.
Ya understood So, I would start by taking one or two zones and putting into a flex schedule. If you like what you see, I would add more. I would group zones by crop type. Also note in a flex schedule, different crop types are going to water at different intervals. So, you could theoretically have a flex schedule where all of the zones are watering on different days, depending on their irrigation needs.
Yep thanks. I see that now. I did exactly what you suggested. I grouped my front yard (3 zones) together and my front flower beds (2 zones) together in flex schedules… These flex schedules are awesome - it’s exactly what I envisioned when I first purchased the Iro!
Now if I could only figure out what type of soil I have!
unfortunately, my area isn’t covered - there are some areas covered nearby (within about 5 mi) that to an untrained observer I could say are “the same” as where I live, but even in those areas that are covered, the soil type seems to vary quite a bit.
What should be entered if there are multiple layers of different soil. For example my area says:
• H1 - 0 to 8 inches: loam
• H2 - 8 to 14 inches: loam
• H3 - 14 to 29 inches: clay
• H4 - 29 to 33 inches: bedrock
Other potentially interesting points:
• Runoff class: Very high
• Capacity of the most limiting layer to transmit water (Ksat): Very low to moderately low (0.00 to 0.06 in/hr)
• Available water storage in profile: Low (about 4.2 inches)
So far I’ve been using clay loam but Iro’s suggested runtimes cause major flooding and runoff. If I remember correctly changing the soil type and recreating the schedule didn’t alter the total runtime, just the cycle/soak time. That was before v2 so maybe things have changed.
