Is there a way to add a soak cycle when you have steep hill to prevent run off.
I have experimented with different soils, nozzles, root depths and times.
Any suggestions?
This matrix shows exact runtimes with different configurations.
http://support.rachio.com/article/283-smart-cycle-overview
Yes I used the Matrix and ideally I would like to run a 15 minute cycle with a 30 minute soak followed by another 15 minute cycle. This would prevent run off on the hill side.
I am guessing that i will be stuck running two separate schedules 30 minutes apart.
I will try again today with different modifications and let you know, but it hasn’t happened up till know.
I have had way to much erosion on the hill side due to the run off.
If you want to have [support@rachio.com] review your schedule just send them an email. Chance it is incorrectly setup (nozzle types, etc.)
