Soil Type? Soil Test Preformed
Hello I had a soil test done what should I set my soil setting below is the test
The Rachio support article What type of soil do I have? includes the soil types in the app as well as a Soil Texture Triangle. Since Silt Loam isn’t directly supported, I’d start with Loam and then modify the Available Water value in the Advanced settings if needed. Since your soil test doesn’t seem to include Available Water, you might use the instructions @azdavidr provided at Web Soil Survey Instructions for Use with Rachio Iro to zero in on your exact number. In your case you may be just fine with Loam, though.
Updated links:
