That solved my problems. Thank you.
Since there is no slider, then button pushers like me get into trouble by trying it out without any way of going back to where we were. Can you add an āundoā button?
Iāll put this in the backlog and we will prioritize accordingly.
I have moisture sensors too, and I donāt understand why my only two options for adjustment of soil moisture are 0 and 100% (i.e. empty and fill). Seems to me that you could walk around with a sensor and set the actual percentages and give the controller a much better idea of what to do. Having a portable sensor could also help the controller ālearnā the drain rate. Anyway, the feature seems really hobbled by only being able to adjust to either endpoint, and nowhere in between.
Agreed. This is definitely in our backlog, will get to this as soon as we can.
I am having a hard time understanding why this particular tool needs to be complicated by adding a slide for %. What is this tools particular purpose? Is it to make a quick correction to input variables either from zone parameters or weather data being off from actual condition in the ground, YES. Is it to fine tune parameter settings NO. IF you want to add choices to the slide OK. Keep them simple and relevant to what is being accomplished. Depleted, Water at next available time or Saturated Delay water 1 day, or 2 days. If these options do not correct the issue, chances are it is improper setting or weather data that needs to be address.
If you want to be able to do this, maybe it should be an option within the zone setup menu but probable not in a quick correction tool.
I am referring to the zone Moisture Fill/Empty tool under iroās zone moisture balance graph.
@ETIrrigation, okay thanks for clarifying.
Are you recommending we add more options to the Fill/Empty tool?
Assuming this is for soil/moisture sensor data. If so, then weād probably want to separate user quick edits from sensor calibration edits. Let me know if weāre on the same page.
I would prefer it stayed just as it is. Empty/Fill no need for a slider here.
I have a few question in regards of moisture level
- Looking at the graph, I can see it shows it will go up from almost empty to full. However I do not see if that will happen due to rainfall or the system that calculates it will need to run the sprinkler for that zone
- I have different nozzle types and even different plants in my zone. Is it wise to keep flexible schedule and try to find a balance between the plants and the nozzle types?
- I have a the famous moisture meter you can put into the ground to read the moisture level. Would it make sense to do that for each zone and then adjust the moisture level to have a good starting point? Is it now possible to set it to a specific level or still only empty or full?
- The default area size is set to 1000 sq ft. That is very big. Not easy to calculate, but mine are way lower like 100 or even less. How much impact does the area have in the calc?
- If the level is empty how much does the system look into the forecast in order to not run the sprinkler? I mean if the system knows in 3 days in will rain, however moisture level is empty, will it still run the sprinkler?
- Is there some kind of a list of plants that shows in what category they are going and their typical root depth?
Thanks
The moisture level is filled by precipitation, or irrigation.
A flex schedule will run each zone independently, so its not that big of an issue. If you want to take advantage of smart cycling, I would group like zones together.
I donāt think that would help much since we are tracking with different data. If you go into the moisture level graph itself, you can empty/fill each zone.
Sq. ft is only used in calculating estimated gallon usage. Nozzle type (in/hr), crop type, and soil are probably the most important data points.
If the zone is depleted, we will run that day, unless enough precipitation is predicted for that day, to offset the current dayās evapotranspiration.
Here are the current crop types with root zone depth in inches:
XERISCAPE 5.0
TREES 25.0
ANNUAL 4
COOL_SEASON_GRASS 6
WARM_SEASON_GRASS 9
PERENNIAL 10
SHRUBS 15
Coming this Spring we will be consolidating fixed and flex into a more simple, understandable, efficient schedule.
Thanks for your detailed answer Franz. I have tried to do the inline replyā¦but was not able to find it.
I think it would be good to see in the forecasted moisture level which part is from precipitation and which part from irrigation. I assume it knows approx how much rainfall is forecasted.
The problem is that I have different nozzle types and plants in the same zone. Means one plant might get a bit too much water and another not enough. But it is obviously difficult unless each zone as just one kind of plant and nozzle type installed
True, but my moisture meter gives me indication if the soil is very dry or wet. I just have a feeling that the current data for my moisture level could be pretty wrong
Good to know. Soil type is typically the same within a zone. I just struggle as I have different crops and nozzle types in the same zone.
Would it make sense to have the option to look at the forecast and even if it is depleted to not run irrigation as the day after rain is forecasted?
I found them on the webpage, but I have a hard time to know if my specific plant is a Xeriscape, perennial etc
Looking forward to the update in Spring then
Thanks
You can just highlight text from the post, and voila!
This is shown in the details.
After more than one day, forecast precipitation data gets a little shaky. I think weād miss more than we hit.
For crop types that are not turf (grass), it is very hard to estimate root zone depth without actually taking a sample. Weāve chosen industry standard estimates, but once again each individual plant will have a different root zone depth.
Hope this helps.
Right, would be nice having however a different icon in the graph for rain and manual watering. Gives the visibility right away if it was due to rain, irrigation or both.
Making my life sometimes more difficult by manually watering directly from the hoseā¦That will be hard to account in Rachio
If you hover over the rain drops in the webapp we do show more detail, but another icon is a good idea for immediately determining what happened.
and if we already talk about visible improvements. When editing a zone and chose the different nozzle or soil types, I think it would be great to have the picture/icon (which is on the webpage explaining the different types) as well to the text
@franz - Re-visiting the topic of offering more than just Fill and Empty, Iād love to have a manual percentage to enter or the slider suggested.
I replaced a sprinkler in one zone and manually tested that zone several times, which got that zone a bit off on the moisture balance away from its two overlapping zones (all three of which have identical characteristics and stay in sync on Flex Daily normally). Now, since they are out of sync, they are scheduled to non-ideally run on different days.
I realized I can use the moisture balance adjustment feature to get them back in sync, but it only works well when the zones are close to full or empty. Otherwise Iād mess up the flex moisture balance tracking too much. Tomorrow they will be pretty close to full, so I set myself a reminder to fix them then, but if I could manually set any moisture balance percentage, Iād be able to do it now while Iām thinking about it and just dial the one back in line.
So yeah, I vote for adding the not-just-full-and-empty moisture level adjustments!
What happened to this being in the ābacklogā 3 years later and there is still no manual entry for soil?
Any update on this feature? I tapped fill to see what the button did (oops) no confirmation, it just filled my soil to 100%. Since it seems thereās no manual entry or undo, thereās no way to change it backā¦
