Just installed Rachio Gen 2 outside. Excited to use it. However, I need a smaller power option. The power adapter is too big for my outside power supply. Can anyone make a suggestion? Something I can get off Amazon, perhaps?
If this is an outdoor installation with the outdoor enclosure, you can plug the power brick into the provided receptacle inside the enclosure - there is enough room. And then you need a pigtailed cable from the enclosure to the mains with a normal plug, which you can get on amazon.com. It will fit and look much better.
Thanks! This is for outdoors. I did a search for pigtail cable on Amazon, but the results seem to be for audio. Would you mind sending me a screenshot or link of what you are talking about?
Perfect! Thanks!
