@rekinowski For seeding a new lawn I’d actually start with the Fixed Schedule on an hourly interval. This will allow you to keep a consistent moisture level and work with any restrictions.
After the lawn has established, you can move into using the Flex Daily schedule.
Totally agree with @timber. The last thing I would ever do is use a flex daily schedule with a new, unestablished lawn. We also do have an hourly schedule type to help a new lawn get established.
After your lawn is established, we can help with setting zone characteristics and adjusting a flex schedule for you.
I also have new seeded lawn and have read a couple of posts regarding this topic. Seems like best option is to use:
Type = fixed
Interval = every hour
Duration = 5m
Cycle and Soak: 7m cycle, 4hr soak
My questions:
How long should each watering event last if I intend to water every 4 hours?
What’s the difference between the “Duration” setting and the “Cycle” setting? If the values are different (as in my case above with 5m Duration and 7m Cycle), what happens?
I ran into a similar situation. My problem with using Fixed Schedule is that I could not figure out how to include a start and stop time. Looks like it would run in hourly intervals for 24 hours when I really only need watering between 10 AM and 6 PM (8 times). I solved it by just setting up 8 separate schedules, but that was a little tedious because you can’t save a schedule with a different name.
