Should be nice to see the calculate precipitation rate presented with the runtime. The math is easy and the data for area per zone is there. Also If you add flow in the advance zone settings the math data is there.
Would be nice to have when you increase or decrease runtimes with + or - to se the calculated
precipitation rate presented there. Then you don’t need to do the math yourself .
