The schedule runs at the time I chose and for the duration it needs. But it doesn’t turn off- or it doesn’t report being turned off. This is the 3rd or 4th day I have checked the Rachio and found it thinking it was still watering.
Does the watering history look OK? Have you tried refreshing the app on your phone? You just swipe down and then release to have it refresh. (At least on IOS, I’m guessing that Android probably works the same way.
I have moved the WiFi router to a new position. My hope is that this helps communication with the Rachio. Can I ask that you take a look at the signal strength? Is there a way for us (the community) to check these things ourselves?
