Run Single Station Manually for x Minutes?
Is there a way to run one specific station manually, for a certain amount of time without creating a schedule?
Yes. See http://support.rachio.com/article/148-manually-run-zones-and-schedules
Thanks, yes I saw that article but I was wondering if thereā€™s a way to run a single station without setting up a schedule for each station individually and just disabling it?
I think you must have misread the linked article: the section headed ā€˜Manually Run Zonesā€™ has a screen shot of the Rachio app with an arrow pointing to a blue button on the screen. Press that button and it takes you to a screen where you can select one or more zones, select watering time(s) for the zone(s) and set them going.
Thanks! Yes, I did miss that the top bar that says ā€œAll Zonesā€ is a drop-down menu where you can select a specific zone and then set the time.
Thatā€™s what I needed!
Yes, it is indeed hard to see. A simple change in coloring of the dropdown icon will make it more visible and obvious that that is a pick list vs simply a title.
