I have a Rain Bird WR2 connected and because temps are falling in the morning below its threshold the unit is skipping a scheduled watering, but by 8-9am the temp has risen, the sensor has deactivated and the unit doesn’t then start the schedule. Is there a workaround for this since that means I will miss a watering and not get more put down for a few days? And because it’s winter this is happening more than not.
@petercw2 My best recommendation would be to change your schedule start time to later in the morning for right now! Unfortunately with rain/freeze sensors, they work to completely stop your system while activated, so there isn’t a great way to override them.
One other option is to turn the physical sensor off and you could use our virtual freeze sensor and adjust the temperature you would like. Just a thought.
