I live in the desert and have strict watering regulations all year long that are specific to each month. I can’t seem to create a schedule that doesn’t require me to manually make a change every few months. If the year was removed from the end date I could have a schedule for each of the different watering periods and forget it. Is there a workaround or integration with some other IOT that can manipulate the schedules all year?
@matware You could look into IFTTT but it might be more confusing. For now I’d probably creates these as autonomous schedules with start/end dates and then once a year you can change the start/end dates (should only take a few minutes). Agreed that leaving the year off would be helpful in some circumstances.
