I have a Relay-pump & well setup that feeds my system, With Gen3 controller.
Do I have a backflow preventer? (See pic) Flow meter mentions needing one?
Will adding flow sensor conflict with a relay pump setup?
I don’t see a back flow preventer in the picture and if you pump isn’t hooked to your potable (inside the house) water, then I don’t think you need a back flow preventer. I don’t see why the flow meter won’t work with your system. May need a longer stabilization time though.
Longer Stabilization ? How ?
Yes they should be per zone, unless an inactive (no zones should be running) alert where we don’t know what zone is leaking.
