Anyone have a recommendation for an external sensor? Also, I need two controllers, due to the number of zones that I have. Will I need two external sensors, or can one feed both controllers?
Thanks.
Thanks.
Here is an article on sensors (wired v. wireless).
http://support.rachio.com/article/217-rain-sensors
Currently, one sensor would be needed for each unit (they don’t communicate with each other).
That functionality is on our road map, but far off.
Hi @garyhooper, good evening. What type of sensor are you looking for? Rain sensor or rain gauge? If the latter, we could install and integrate a PWS to both stations with only ‘one sensor’. I’d recommend the Netatmo if you’re interested in this option.
Hope this helps.
Best, Emil
