#!/usr/bin/php
<?php
* PHP client for Rachio Irrigation controller
* The Rachio irrigation controller has great hardware. The Android and web
* apps are also pretty decent. However, in my personal opinion, their watering
* model hasn't worked out that great for me: your mileage may vary. Gratefully,
* they have provided API access that allows for custom watering models such as
* this one.
* Includes a custom tweakable temperature based watering model
* LICENSE: The MIT License (MIT)
* Copyright (c) 2015 Waheed Ayubi
* Permission is hereby granted, free of charge, to any person obtaining a copy
* of this software and associated documentation files (the "Software"), to deal
* in the Software without restriction, including without limitation the rights
* to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
* copies of the Software, and to permit persons to whom the Software is
* furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in all
* copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
* AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
* OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
* SOFTWARE.
* @author Waheed Ayubi <wayubi@gmail.com>
* @copyright 2015 Waheed Ayubi
* @license http://opensource.org/licenses/MIT MIT License (MIT)
* @link https://github.com/wayubi/Wachio
namespace W;
class Model
private static $rain_check_days = 2; // max 10
private static $debug = false;
private static $calendar = array(
1 => array( 'name' => 'January', 'temperature_basis' => 'Low', 'multiplier' => 1.0 ),
2 => array( 'name' => 'February', 'temperature_basis' => 'Low', 'multiplier' => 1.0 ),
3 => array( 'name' => 'March', 'temperature_basis' => 'Avg', 'multiplier' => 1.0 ),
4 => array( 'name' => 'April', 'temperature_basis' => 'Avg', 'multiplier' => 1.0 ),
5 => array( 'name' => 'May', 'temperature_basis' => 'Avg', 'multiplier' => 1.0 ),
6 => array( 'name' => 'June', 'temperature_basis' => 'High', 'multiplier' => 1.0 ),
7 => array( 'name' => 'July', 'temperature_basis' => 'High', 'multiplier' => 1.0 ),
8 => array( 'name' => 'August', 'temperature_basis' => 'High', 'multiplier' => 1.0 ),
9 => array( 'name' => 'September', 'temperature_basis' => 'Avg', 'multiplier' => 1.0 ),
10 => array( 'name' => 'October', 'temperature_basis' => 'Avg', 'multiplier' => 1.0 ),
11 => array( 'name' => 'November', 'temperature_basis' => 'Avg', 'multiplier' => 1.0 ),
12 => array( 'name' => 'December', 'temperature_basis' => 'Low', 'multiplier' => 1.0 ),
public static function getRainCheckDays()
return (int) static::$rain_check_days;
public static function getTemperatureBasis($timezone)
date_default_timezone_set($timezone);
return static::$calendar[date('n')]['temperature_basis'];
public static function getAdjustedRuntime($basis, $temperature)
if (static::$debug) return 1;
$multiplier = (float) static::$calendar[date('n')]['multiplier'];
return (int) ( $basis * $temperature * .01 * $multiplier );
class Rachio
private static $api_token = '==== ENTER YOUR RACHIO API KEY HERE ====';
private static $rain_delay_days = 7; // max 7
private static $zones = array(
1 => array( 'name' => 'Zone 1 - Parkway', 'runtime_basis' => 8),
2 => array( 'name' => 'Zone 2 - Front Yard', 'runtime_basis' => 22),
3 => array( 'name' => 'Zone 3 - Office Garden', 'runtime_basis' => 0),
4 => array( 'name' => 'Zone 4 - Back Yard', 'runtime_basis' => 22),
5 => array( 'name' => 'Zone 5 - Fruit Trees', 'runtime_basis' => 98),
6 => array( 'name' => 'Zone 6', 'runtime_basis' => 0),
7 => array( 'name' => 'Zone 7', 'runtime_basis' => 0),
8 => array( 'name' => 'Zone 8', 'runtime_basis' => 0)
public static function run()
$api_token = static::$api_token;
$result = Curl::request('https://api.rach.io/1/public/person/info', array(
'Content-Type: application/json',
"Authorization: Bearer ${api_token}"
$person_id = $result->id;
$result = Curl::request("https://api.rach.io/1/public/person/${person_id}", array(
$device_id = (string) $result->devices[0]->id;
$rain_delay_start = (int) $result->devices[0]->rainDelayStartDate;
$rain_delay_expiration = (int) $result->devices[0]->rainDelayExpirationDate;
$rain_delay_active = (boolean) ($rain_delay_expiration >= $rain_delay_start) ? true : false;
$timezone = (string) $result->devices[0]->timeZone;
$zip = (string) $result->devices[0]->zip;
$zones = (array) $result->devices[0]->zones;
Wunderground::request($zip, $timezone);
$rain_delay_wunder_active = (boolean) Wunderground::rainForecast();
if ($rain_delay_wunder_active) {
$json = json_encode(array(
'id' => $device_id,
'duration' => static::$rain_delay_days * 86400
$result = Curl::request("https://api.rach.io/1/public/device/rain_delay", array(
), 'PUT', $json);
$rain_delay_active = true;
if ($rain_delay_active) {
echo '=== Stopping: Rain Delay ===' . PHP_EOL;
return;
$temperature = (int) Wunderground::getTemperature((string) Model::getTemperatureBasis($timezone));
$start_zones = array();
foreach ($zones as $zone)
$id = (string) $zone->id;
$zoneNumber = (int) $zone->zoneNumber;
$name = (string) $zone->name;
$enabled = (boolean) $zone->enabled;
if (!$enabled) continue;
$runtime_basis = (int) static::$zones[$zoneNumber]['runtime_basis'];
$runtime_adjusted = (int) Model::getAdjustedRuntime($runtime_basis, $temperature);
$start_zones[] = array(
'id' => $id,
'duration' => $runtime_adjusted * 60
$json = json_encode(array('zones' => $start_zones));
$result = Curl::request("https://api.rach.io/1/public/zone/start_multiple", array(
), 'PUT', $json);
echo "=== Done: Lawn Watered ===" . PHP_EOL;
class Wunderground
private static $api_token = '==== SIGN UP FOR A FREE API TOKEN AT WUNDERGROUND.COM ====';
private static $data = array();
public static function request($zip, $timezone)
$result = Curl::request("http://api.wunderground.com/api/${api_token}/forecast10day/q/${zip}.json");
$forecastdays = $result->forecast->simpleforecast->forecastday;
$data = array();
foreach ($forecastdays as $forecastday) {
$date = (string) date('Y-m-d', $forecastday->date->epoch);
$high = (int) $forecastday->high->fahrenheit;
$low = (int) $forecastday->low->fahrenheit;
$rain = (boolean) $forecastday->qpf_allday->in;
$data[$date] = array(
'high' => (int) $high,
'low' => (int) $low,
'avg' => (int) (($high + $low) / 2),
'rain' => (boolean) $rain
static::$data = $data;
public static function rainForecast()
$rain_check_days = Model::getRainCheckDays();
$i = 0;
foreach (static::$data as $data) {
if ($i == $rain_check_days) break;
if ($data['rain']) return true;
$i++;
return false;
public static function getTemperature($basis)
return (int) static::$data[date('Y-m-d')][strtolower($basis)];
class Curl
public static function request($url, $headers = array(), $method = 'GET', $postfields = null)
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, $url);
if ($method == 'PUT') {
curl_setopt($ch, CURLOPT_CUSTOMREQUEST, 'PUT');
curl_setopt($ch, CURLOPT_POSTFIELDS, $postfields);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
curl_setopt($ch, CURLOPT_HTTPHEADER, $headers);
$result = curl_exec($ch);
curl_close($ch);
return json_decode($result);
\W\Rachio::run();
