Another Tenda Nova MW6 user here that is unable to connect. There were some good deals on this WiFi system recently and is one of the cheaper mesh solutions so there may be some new users out there with issues. For now I can run a old access point for the Rachio but so far it is the only device I have out of 30+ devices in my home that have this issue.
I’ve had my gen 3 for 6 months with wifi issues off and on, usually fixed by power cycling. But for the last few weeks I have barely been able to connect. I have a Netgear Orbi router, which uses the same SSID for both bands. There is no option to use a separate SSID. Power cycling the router seems to help sometimes, but not for long. I shouldn’t have to power cycle a router daily to keep a single device happy. All other devices, including wifi cameras in the same area, work just fine. Why can’t Rachio fix these issues???
@inglewtx - I’d recommend running the RouteThis app and send the key into Rachio support so they can have some additional information on the network setup.
My Orbi router and 2 satellites are on the latest firmware, and have worked very well for all of my wifi devices
(including 8 high res wifi cameras) except the Rachio.
I’ve done RouteThis with Rachio support before, and we didn’t get anywhere. After I added the 2nd Orbi satellite near the Rachio, everything worked well for several months. But the Rachio has mostly been offline for the last 2 weeks or so, despite constant reboots (including the Orbi and satellites).
I’m not going to replace Orbi after such a significant investment, and when everything except Rachio works.
Would you be up for working with our support team some more to see if we can work through this together? I didn’t see a response in your previous ticket regarding our agent’s suggestions, but we’d love to know the results! Feel free to start a new ticket or just respond to the previous one and we can get this sorted out ASAP
Thanks Laura… I definitely will. Naturally, the wifi connection started working for now (for no apparent reason), so I’ll wait and contact support the next time it goes down. Thanks
Having the same issue, used the Routthishelp and got key XXGZKRAV. I’ve reset router and ensured it’s on WPA 2, reset Rachio controller Section 2 is flashing yellow. When I try to connect through the app it scans for networks in area, then asks “which Wi-Fi network should Rachio use?” but there are no networks listed… please help
@K2K19 - which flavor of the app - iOS or Android?
Is the app up to date?
Is the WiFi a mesh system?
And just checking that the phone’s WiFi setting is on and that local WiFi networks haven’t been forgotten (if it is an iOS based device)?
I might email support@rachio.com or use the app to sent a support ticket with the RouteThis code as they can look at that report when end user community members can’t.
Android, deleted and reinstalled the app again today to ensure it’s updated, not running a mesh system. WiFi on the phone is on, did the same thing with my wife’s Android. I will send them an email too.
I am having the same troubles as many of the previous users. I have a Tenda Nova MW6 mesh WiFi system, and am currently unable to connect my newly installed rachio3. I have ‘excellent’ connectivity at the controller location, and have no other connection issues with other smart devices. Would you please help identify the beat way to resolve the connection issue.
@abalcer - run RouteThis either in the Rachio app (I think accessible from the red off-line banner) or the stand alone app. If using the stand alone app version then email the code that is returned from RouteThis to support@rachio.com.
Which flavor of Rachio app are you using - iOS or Android? If Android, do you have access to an iOS device to perform the initial setup (sometimes iOS works better on the initial setup)?
I haven’t seen a post update where the WiFi chip vendor has solved the problem of previous posters with the Tenda Nova mesh WiFi - yet. Maybe @Franz has an update.
@Abalcer We never got a resolution from our WiFi vendor regarding Tenda Nova compatibility. Our support team might have a workaround, but the last I heard our WiFi module did not support that router. Sorry for the news.
For those having connectivity issues, it may be time for a router replacement/upgrade. I highly recommend the Synology offerings. They have a regular single-unit router, as well as a Mesh option. Check them out!
