This is a new problem for me. When I try to manually run a zone, no matter how much time I tell it to run, it stops after 40 seconds. Not sure it this is something I inadvertently enabled or what.
Thanks
Thanks
Ok, actually I figured it out after looking at the history. I have this integrated with Home Assistant with some node-red flows and the way I had it set up, it was basically turning off any station every minute :(, so it seems to be working as normal now.
Does the Home Assistant component work for you? In my case, it shows the zones/switches, but it does not activate the sprinklers or reflect the actual status… Any help?
