I would like to suggest a product improvement for your power supply. Since my Rachio is installed in the garage next the the door to the house, the power supply always falls out of the socket after multiple people open and close the door. I would like to suggest that you include a screw mount to securely attach it to the receptacle. This way it will not fall on the floor taking the magnetic Rachio cover with it.
PS becomes loose after laundry room door is closed a few times
PS eventually falls out and pulls magnetic cover off with it
Here is my current solution for the issue with the PS
I recommend the power supply be able to attach to the receptacle like this other 24VDC adapter.
Note: All the receptacles are new so the connection is tight.
