I think could be great if I can use my unused control zones of Iro to control the Pool Filtering, it just need to program a schedule to run every day once or two times for example.
I want to get cloud control of my pool filtering, and there is nothing to do that.
Can you setup a fixed schedule to do this now? Is there other functionality (other than changing the crop type to pool and disabling smart watering features) that you are thinking of?
Thanks for your reply and I`m sorry for my delay on respond.
I canĀ“t use a disabled zone because if I run any other zone irlo will try to start the master pump do you have any way to disable the master pump on some zones schedules?
Hi Emil, I got an old fashion controller. It`s a dummy clock where you select every 15 minutes if you want or not to filter.
It works, but there is no remote control, in case of power failure you need to reconfigure the correct time, etc.
The algorithm needed to optimally run a pool filtration pump is:
10 hours/day if water (not ambient air) is at 90 degrees
5 hours if water is at 50 degrees
assuming itās a properly sized pump and itās a single speed pump.
If itās a dual speed pump, and if youāre running the pump at low speed, then just double the numbers above. I.e.
20 hours if water is at 90 degrees
10 hours if water is at 50 degrees
You should let pump (filter) ārelaxā once half way in between the daily run time, for 15 minutes.
Use this as a guide to see how pool water temperature various as a function of month of year: http://www.welserver.com/perl/plot/WEL0343/PoolWater.png . In my case, I have to run the filter pump 20 hours per day, on low speed, during the height of the summer. Right now I should be running it about 10 hours per day on low speed.
Iām sure this sort of āzoneā would be easy enough for the Rachio guys to set up.
I realize Iām new to this forum. This being my first post and all.
Iāve had my Iro for about a year now. But, until just this past weekend, it was just controlling four sprinkler zones. (Four unused zones!)
My thoughts were, even when I bought it; was that itād be awesome for controlling my pool as well. So, I put one of the unused zones to work.
I wired zone 5 to a pump start relay (orbit) and connected to my single speed 2hp pool pump. It works perfectly. Spent a bit of time fooling with the app trying to figure out which type of schedule would work best. I created a custom sprinkler nozzle that uses basically no water. As no to skew the regular sprinkler zones usage numbers. Currently, Iāve just got it on a fixed daily schedule. I just canāt help thinking that with the Iroās capabilities, it could be so much more.
