IHi there, I’m having an issue with my Gen 1 Rachio.
It says that it’s watering in but it is not. I’ve tried all zones in manual and it says it’s watering, but it is not.
If I manually turn the valve/solenoid at the junction box, the sprinklers work. It seems to not be sending a signal to the sprinkler system even though it thinks it is.
Are there and tips to try? I’ve reset the wifi network and rebooted the rachio. I have a solid power light, flashing green wifi light, and a blue status light (when I activate a zone manually).
Thank you.
Glen.
