Can I use Rachio controller outside USA? When you create an account your are asked to input a zip code in order to use weather conditions… zip code is not valid in Ecuador
Hey @Francisco-
If you have to put in your zip code during setup, go ahead and just put in any US zip code. From there, you can finish the initial setup and once you are in the app you can change your weather station to one close to you! Make sure your location services are on during this setup on your device, if you want you can turn them off after Let me know how that goes and if you need any more help!
McKynzee
Thanks McKynzee. I’ll let you know
