After the latest Android update, the moisture graph no longer renders at all. Previously it may have taken a try or two to get it to render. Now it does nothing, no matter how many times you try.
Android 6.0 on a droid turbo 2.
Mike
Mike
Thanks, development team is looking into this, will have a fix shortly.
As a workaround the webapp moisture graph currently renders.
Is this for iOS also? I switched to a PWS from a reliable one and when I went to check moisture graph it doesn’t show
Yes, iOS and Android. Something is not working on the Webapp server that renders these for both clients, will be fixed as soon as development has found the issue.
Ok thanks. I thought it was a PWS thing which obviously would have sucked
Fixed, might have to logout/login for caching reasons.
