My wife has recently become interested in hot pepper planting, and to make our lives easier, I’ve been looking at adding a simple patio drip irrigation system from the hose bibb/spigot in our backyard.
In my search, I’ve found similar items (Not sure if links to “competitors” are kosher, but specifically the Wise Orchard - https://wiseorchard.com/), but I like my Rachio controller for my in-ground irrigation, and would like to keep it all in the family, as it were.
Mostly I’m trying to pitch this idea, as I think it’d be neat to be able to use the Rachio software/smarts, and am also secretly hoping there are as-yet unannounced plans for something along these lines.
I’m going to prefface this by saying I’m not the code police…
One issue with a setup like this is that if you have a vacuum breaker on your hose bibb, you will run into problems with it leaking when the valve is not running.
If you don’t have one, or remove the vacuum breaker from the hose bibb, you technically aren’t code and the possibility is there that you could get some backflow into your house potable water.
