Yesterday I installed a new system with a 8 zones controller. I’m using the monthly flexible schedule, the outdoor temperature is around 40F during the day and 20F in the night. My question is, why the controller scheduled watering when its too cold? I’m using my PWS and the controller seems to be getting the correct data. Is this the correct behavior? Again this is my first system so any advice will be appreciated.
@fpuig, yes this is correct behavior as the schedule is derived from the historical ET in your area. Rain & local weather (freezing temps) are applied at the skip level. It’s important to remember that plants need water, even in the winter – especially trees.
@fpuig Keep in mind that as long as you have our freeze skip feature enabled, the controller will skip waterings when the anticipated temperature is below freezing! This way your pipes stay safe
@mckynzee - Thanks for the info. It was enabled using the “Freezing” option. I’m assuming “Freezing” default option should be 32F? Any recommendation of what should be a good value? also, could you please reset the water consumption on my account for me? This usage basically was during the system installation.
I think 32F is a good call, but I’ve seen people go a little higher just to be extra safe. And yes- freezing is 32F!
Absolutely, I can reset that for you now. Just so you know, it will not clear today’s usage if I do it today- only previous usage. Is that alright, or would you like me to do it tomorrow morning?
Hi @npp-
Do you mind posting a screenshot of what you are seeing for me? I would guess it is in the “smart features” section, however I’m curious as to what screen you are on…
McKynzee
