so far my worst ever DIY project
After spending 8 hours to install my Rachio worked okay for may be 15 minutes and then wen t off line. I have tried following options
Wifi Reset: Worked for 2 minutes and then again off line
Master reset: Never worked
Changed Wifi to 2.4GHz guest network with only Rachio connected … its gets connected and confirms but afterwards when you press done the blue “circle of death” appears with the message verifying connection and nothing happens. After 5 minutes it goes to sleep and there is no device connected.
