I have tried to set up several different schedules and none would run. The only way I have to run the sprinklers now is doing it manually. I have reached out to tech support several times but to no avail and there isn’t a phone number to contact a human for trouble shooting
Double check to make sure that your controller is not in standby mode.
Also Rachio’s support number is 1-844-472-2446
Also check to make sure you are not in a rain delay. If you have it connected to a weather station and have smart watering turned on, and have had rain, it may not turn on automatically for a week or more.
Thank so much guys for your responses. I have since figured out the problem but your input was extremely valuable.
Can you share what your issue was, just so future people searching this topic know?
