I use a flexible monthly schedule to water my entire yard that runs every third day. I also run a daily schedule to supplement a few areas of the yard that need more water due to a lot of sun exposure. How can I get the daily schedule to not run on the days the flexible monthly schedule runs? They are both scheduled to start at 5 am, and when set to run on the same day the run one after the other.
Maybe thereās something you can do with IFTTT ? I was thinking āIf zone startedā then āskip watering timeā, but It doesnāt seem like you can specify the zone for āzone startedā. Anyway, it might be worth a look.
Would it work to put a rain sensor under your sprinklers in the sunny area? Kind of goofy - the sensor would override the 2nd schedule if it was still wet.
I had this same thought Would be a little funky, but could work! Let me check out IFTTT
I thought of using IFTTT to say if āfull schedule ranā than donāt run "sun zones schedule ", but couldnāt figure it out.
I do have a rain sensor but hadnāt tried that.
